Adding Manual Mobile Network Selection to the GUI
Would it be possible to add support for manually selecting mobile networks to the GUI? I understand this can be done using AT commands, but I think a GUI would be nicer with each network and its corresponding RAT (Radio Access Technology), like 4G or 5G. Would make the Puli AX the perfect travel router when roaming abroad.
  1. If you want to specify 4G or 5G connections, here is the Band Masking, you can only select the LTE Bands.
  1. Select the ISP operator will be implemented in v4.8 firmware, under development.
Hi @bruce,
That's great news! That was the main thing missing I wanted. Do you know if it will show 4g or 5g next to each one?
Not sure if this would need to be a new thread to ask this question. But is there any plans to more conditions to dual sim fail over other than ping? For example based in RSRP or data left on sim or the ability to swap between esims rather than the 2 physical?
Thanks again
  1. It can show the 4G or 5G on cellular title.
  2. The relativity complex SIM switching rules such as RSRP may not be considered, but simple rules such as data left will be considered. Thanks.
