After setting the bgscan (option bgscan 'simple:30:-80:120') in the wireless configuration for STA, this option is continuously deleted because the STA is rewritten after connecting to the network via the GL.iNet UI. Is there any way to prevent this option from being deleted?
We checked the behavior you mentioned. When the Repeater STA configuration is recreated after connecting through the GL.iNet system, manually added options such as bgscan may be removed.
Unfortunately, there is currently no available method to prevent this option from being automatically removed when the STA configuration is regenerated.
Thank you for your understanding and support.
