Adding Proxy to Tinyproxy
I am in need of some help as this is not my forte.
I have GL iNet Opal and Beryl AX
Both have LuCI with Tinyproxy and Squid.
My goal is to add a proxy to the routers so that all traffic that goes through the router goes through the proxy.
I will greatly appreciate if anyone can do a step by step guide on how to do this assuming that I am dumb and that I have 0 knowledge. That way I don’t have to come back with stupid questions.
I have a proxy that allows connections using a whitelist ip. The information I have about my proxy is IP:Port
Please help finding this solution.
Kind regards
Were you able to achieve this?
So did you find any guide on how to do it ? I have been searching all over internet and can't find anything how to setup on Gl.inet. I install the luci-tinyproxy and but settings are so confusing
