Additional Tailscale Issues on 4.2
I have been testing the Tailscale implementation, and although a couple of features work, quite a few important features do not:
  1. Subnets behind other endpoints
    When connecting to Tailscale, there is no option to allow the router to accept advertised subnet routes from other nodes. Therefore, these subnets do not appear in the routing table.
  2. Split DNS
    Tailscale has the ability to advertise DNS servers to it’s clients, so that clients can resolve internal DNS names. However, the tailscale implementation (at least the AX1800) does not propagate split dns settings to the dns server running on the travel router.
  3. Custom exit nodes
    The custom exit nodes slider has a comment about allowing subnets from the device using the Tailscale admin console. For me that did not work. No subnet appears in the admin console for the router. Also, I was not able to reach the internet when using an exit node (checked the ACLs)
this issue made tailscale unusable for me, we need some way to allow routes from ts
Same here. I need to be able to access company hosts behind a subnet router when travelîng. At this point my only option is to run tailscale directly on all of my devices. I’ve tried wireguard, but there i have the issue that i can not run multiple instances at once - even when on different ports.
