goode
May 3, 2026, 2:08pm
I think it would be beneficial and very intuitive to have a connection and/or address manager for router and devices.
Sometimes it seems as if when the app updates or it cannot connect, it will delete the devices on the app and you have to add them back.
Adding a place to backup configuration would be key as well.
Sometimes connections are via VPN or other means, so I think this would be a great addition to the app
admon
May 3, 2026, 2:13pm
2
Huh, never happened to me so far.
You mean that you need to delete the whole device from the app instead of just forcing the app to quit and restart it? Are we talking about iOS or Android?
goode
May 4, 2026, 8:12am
3
Whenever the app receives an update…or it fails to connect, sometimes it will delete devices in the app, and you have to re-add devices
This is android
system
Closed
August 2, 2026, 8:13am
4
