Adguard allow a domain?
I have the GL-iNet AXT1800. I turned on Adguard. I have a lot of block lists loaded. There is a single URL that is currently being blocked, and I want to just make it so that one URL is allowed. How can I do this? I am used to pihole, and it is simple to click on the blocked URL and add it to an allowed list.
Appreciate the help
Same on AdGuard Home.
You need to create a whitelist and add the domain you don't want to get filtered.
Not sure if you can whitelist by viewing the log and push a button, tho.
You can check domain which filter blocked by?
Filter > Custom filtering rules > scroll down
In Filters > DNS Allowlists, I can add the allowlist. But that is just a URL to a list somewhere. Where can I host that allow list? Is that something that can be fully self-contained in the AXT1800 router? I am hoping I do not have to host that file on some other secure accessible location online.
Thanks
Use custom rules instead and add @@||example.org^ to unlock example.org
Nevermind, found it:
Open Query Log tab
Search for the blocked domain you want to allow
run the mouse over the item towards the rightmost end of the record, and "Unblock" magically appears. Click it and you can unblock for the client.
A special line is then added to the Filters > Custom Filtering rules.
Cheers.
