AdGuard crash my routers
Everytime I try to turn on AdGuard on a Marble or a BerylAX the router crash, and AdGuard doesn't turn on.
The lists I have chosen are:
GitHub - hagezi/dns-blocklists: DNS-Blocklists: For a better internet - keep the internet clean! (this Pro++)
Once I have chosen, router crash and I can't turn off adguard or remove this list. I have to reset it
Any idea?
Please try to update AdGuard Home to the newest version: [Script] Update AdGuard Home
Anyway, your list could be too big - in that case you need to reduce the amount of entries.
How can I do it if AdGuard freezers? Is anyway to change configuration?
You can delete the whole AGH config by stopping AGH and removing the data.
Either by adjusting the config.yaml or by deleting everything, see
Thank you. Really useful!
