AdGuard Home API access broken after v4.9.0 firmware upgrade - requires GL.iNet Admin-Token
Router: GL-BE9300 (Flint 3) Firmware: Upgraded from v4.8.1 to v4.9.0 AdGuard Home version: 0.107.73
What I had working before the upgrade:
I use Home Assistant to manage AdGuard Home's per-device service blocking (YouTube, social media, gaming etc.) via the AdGuard API. My setup uses bash scripts that authenticate to AdGuard using the standard cookie-based login flow:
  1. POST to /control/login with AdGuard credentials → receive agh_session cookie
  2. Use that cookie for subsequent API calls to /control/clients, /control/clients/update, /control/status etc.
This worked perfectly on the previous firmware version. I also had the Home Assistant AdGuard integration connected successfully.
What's broken after the upgrade:
After upgrading to v4.9.0, all API access to AdGuard Home returns 401 Unauthorized, despite successful login. Specifically:
  • Login to /control/login succeeds (returns 200 OK, sets agh_session cookie)
  • Any subsequent request using that cookie returns 401
  • Basic Auth (Authorization: Basic ...) also returns 401
  • This happens both on port 3000 (direct) and through the nginx proxy on port 80
  • Tested from localhost (127.0.0.1) on the router itself - same result
  • Deleted and recreated sessions.db - no change
  • The AdGuard web UI works fine through the browser
What I discovered:
The browser accesses AdGuard through GL.iNet's nginx proxy at /control/, and authenticates using the GL.iNet Admin-Token cookie — not the AdGuard agh_session cookie. When I manually copied the Admin-Token from my browser and used it in a curl request, the API worked:
bash
curl -s -H 'Cookie: Admin-Token=<token>' http://127.0.0.1/control/status
# Returns valid JSON response
However, I cannot obtain this token programmatically. The GL.iNet RPC login endpoint returns "Access denied" even with the correct password:
bash
curl -s -X POST -H "Content-Type:application/json" http://127.0.0.1/rpc \
  -d '{"jsonrpc":"2.0","id":1,"method":"call","params":["","login","login",{"password":"<correct_password>"}]}'
# Returns: {"id":1,"jsonrpc":"2.0","error":{"message":"Access denied","code":-32000}}
It appears that the v4.9.0 firmware (or the bundled AdGuard 0.107.73 with CVE-2026-32136 fix) has changed how authentication works. AdGuard's own session cookie mechanism no longer functions - all API access now seems to require GL.iNet's Admin-Token, which can't be obtained programmatically via the RPC API.
What I need:
  1. A way to programmatically obtain the Admin-Token via the RPC API (is my login call format correct?)
  2. Or: a way to make AdGuard's native cookie/basic auth work again
  3. Or: documentation on the correct way to access the AdGuard API on v4.9.0
This is blocking all Home Assistant integration with AdGuard Home. Any help appreciated!
For information on how to use the GL.iNet API, please contact us at support@gl-inet.com.
If you do not mind that configuring a username and password will break the integration between our router GUI and AdGuard Home, you can refer to the following thread to configure AdGuard Home independently:
Thanks for the info.
I was able to access this way prior to the update but I can’t remember if it was because I did this modification previously. :person_shrugging:
Would I have had to have done this in firmware version 4.8.1? I have come up with a workaround, which I’ll post down below, but it doesn’t fix the Adguard Home Integration problem. Maybe that’s a clue that I must have followed this before….
If you mean that it must to manually modify the AdGuard Home configuration file in order to log in to the AdGuard Home management interface with a username and password, then yes — v4.8.1 behaves the same way as well.
I can confirm the same issue that gezr is having after updating to 4.9.0
Previously on 4.8.4, the only change required to access AdGuard via the API access would be to update the config.yaml file to include a username/password and restarting adguard to read from the new config.
After upgrading to 4.9.0, this no longer works and returns 401 result when trying to use the API.
I then downgraded back to 4.8.4 (not keeping any settings). After updating the config.yaml file to include a user/password and running /etc/init.d/adguardhome restart, API access is available again.
