For FLINT 2-
I have a question about configuring the adguard to local Lan interfaces with ip4 and ip6W
which ip6 (apart from::1) from the below is equivalent to lan IP4 version ( 192.168.1.1) that I should insert in Yaml file?
For FLINT 2-
You don’t need insert local IP dns addres your device. DHCP will auto insert to your Flint 2.
The one with br-lan interface should work just fine.
You should enable Network → DNS → Override DNS Settings for All Clients as well, so you don’t have to take care about anything.
