Adguard Home DHCP server
When trying to disable the DHCP server on my Marble and enable the DHCP server in Adguard Home I get the following message:
In order to use DHCP server a static IP address must be set. AdGuard Home failed to determine if this network interface is configured using a static IP address. Please set a static IP address manually.
How do I set a static IP manually?
I tested it on a Marble router running V4.5.22 and successfully enabled the Adguard Home function.
Which version are you currently using? You may try upgrading to V4.5.22 and testing it again.
Yeah, I figured out the issue. Using the DHCP server in Adguard Home requires a static ip on the wan interface before you can enable it.
