Adguard Home - DNS Query Log Issues
I'm running a GL-MT6000 on Firmware v4.6.8.
I understand that via the GUI Adguard Home maintains a limited amount of DNS Query history. The problem I'm facing is that the logs seem to be removed at an exceedingly fast rate.
The best example of this would be Malware/phishing logs from the Adguard security service. I'd see some events in the dashboard, but if I haven't gone to view them in a period of around 15 minutes, they are no longer visible. This is quite frustrating.
Over 7 days I would normally have around 400,000 DNS Queries through Adguard Home. Is there something I can do to retain the logs for a longer period?
The logs are RAM only by default:
Thanks for the assistance. However, it appears enabling that option may accelerate the wear on the inbuilt storage on the router. I really wanted to enable it :slight_smile:
It totally does, of course.
You could use an USB storage instead.
