I am using the default router (GL-MT6000) configuration with just IPv6 Passthrough and AdGuard Home enabled (all done via the GLiNet GUI), I have not done any other customization, after checking the logs I found a lot of AdGuardHome errors, actually hundreds, they are all the same type of errors, do you know what they mean and how can I stop and fix them, these logs repeat every minute:
Fri Aug 23 13:38:40 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:40.655757 [error] dnsproxy: 127.0.0.1:53: response received over udp: "exchanging with 127.0.0.1:53 over udp: read udp 127.0.0.1:59252->127.0.0.1:53: i/o timeout"
Fri Aug 23 13:38:40 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:40.655757 [error] dnsproxy: [::1]:53: response received over udp: "exchanging with [::1]:53 over udp: read udp [::1]:39174->[::1]:53: i/o timeout"
Fri Aug 23 13:38:40 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:40.655947 [error] dnsproxy: upstream [::1]:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.00192505s: exchanging with [::1]:53 over udp: read udp [::1]:39174->[::1]:53: i/o timeout
Fri Aug 23 13:38:40 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:40.655905 [error] dnsproxy: upstream 127.0.0.1:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.002677801s: exchanging with 127.0.0.1:53 over udp: read udp 127.0.0.1:59252->127.0.0.1:53: i/o timeout
Fri Aug 23 13:38:46 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:46.095714 [error] dnsproxy: [::1]:53: response received over udp: "exchanging with [::1]:53 over udp: read udp [::1]:36369->[::1]:53: i/o timeout"
Fri Aug 23 13:38:46 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:46.095829 [error] dnsproxy: upstream [::1]:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.001369338s: exchanging with [::1]:53 over udp: read udp [::1]:36369->[::1]:53: i/o timeout
Fri Aug 23 13:38:46 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:46.095714 [error] dnsproxy: [::1]:53: response received over udp: "exchanging with [::1]:53 over udp: read udp [::1]:35917->[::1]:53: i/o timeout"
Fri Aug 23 13:38:46 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:38:46.095918 [error] dnsproxy: upstream [::1]:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.002262581s: exchanging with [::1]:53 over udp: read udp [::1]:35917->[::1]:53: i/o timeout
Fri Aug 23 13:39:08 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:08.208577 [error] dnsproxy: 127.0.0.1:53: response received over udp: "exchanging with 127.0.0.1:53 over udp: read udp 127.0.0.1:38649->127.0.0.1:53: i/o timeout"
Fri Aug 23 13:39:08 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:08.208707 [error] dnsproxy: upstream 127.0.0.1:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.001511155s: exchanging with 127.0.0.1:53 over udp: read udp 127.0.0.1:38649->127.0.0.1:53: i/o timeout
Fri Aug 23 13:39:08 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:08.208574 [error] dnsproxy: [::1]:53: response received over udp: "exchanging with [::1]:53 over udp: read udp [::1]:53199->[::1]:53: i/o timeout"
Fri Aug 23 13:39:08 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:08.208786 [error] dnsproxy: upstream [::1]:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.001701003s: exchanging with [::1]:53 over udp: read udp [::1]:53199->[::1]:53: i/o timeout
Fri Aug 23 13:39:08 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:08.209497 [error] dnsproxy: [::1]:53: response received over udp: "exchanging with [::1]:53 over udp: read udp [::1]:41490->[::1]:53: i/o timeout"
Fri Aug 23 13:39:08 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:08.209604 [error] dnsproxy: upstream [::1]:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.001374812s: exchanging with [::1]:53 over udp: read udp [::1]:41490->[::1]:53: i/o timeout
Fri Aug 23 13:39:13 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:13.667060 [error] dnsproxy: 127.0.0.1:53: response received over udp: "exchanging with 127.0.0.1:53 over udp: read udp 127.0.0.1:34000->127.0.0.1:53: i/o timeout"
Fri Aug 23 13:39:13 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:13.667156 [error] dnsproxy: upstream 127.0.0.1:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.001313591s: exchanging with 127.0.0.1:53 over udp: read udp 127.0.0.1:34000->127.0.0.1:53: i/o timeout
Fri Aug 23 13:39:13 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:13.667882 [error] dnsproxy: [::1]:53: response received over udp: "exchanging with [::1]:53 over udp: read udp [::1]:34157->[::1]:53: i/o timeout"
Fri Aug 23 13:39:13 2024 user.notice AdGuardHome[6543]: 2024/08/23 17:39:13.667969 [error] dnsproxy: upstream [::1]:53 failed to exchange ;lb._dns-sd._udp.0.10.10.10.in-addr.arpa. IN PTR in 2.001257354s: exchanging with [::1]:53 over udp: read udp [::1]:34157->[::1]:53: i/o timeout
Also, those timeouts in the logs sync with the AdGuard Home dashboard, with response times over 1 sec
