Adguard home force HTTPS for admin panel
I need to make adguard home admin panel work only via HTTPS.
I found this guide but it's not very clear.
Can I just use same certs as those that used in GL admin panel?
No, i can't use HTTP as I set all my OSes to drop all connections without SSL cert to prevent SSL strip or other attacks. Because of this I cannot open plain HTTP pages even in LAN.
Certificates from GL Web UI can be used on the ADG.
However, the local certificate is a self-signed certificate, not signed by a CA certificate, so the browser may remind you of distrust.
You can also apply in the CA and generate a trusted certificate yourself.
Thanks @bruce I'm being wondering the same thing for a while :call_me_hand:
