AdGuard Home - New router
I've just purchased another Flint 2 router for our office, separate from my existing network. I've set up AdGuard Home with some custom configurations, and I'd like to replicate those settings on my new router.
However, I can't find any option to save or export the AdGuard settings. Do you have any suggestions?
Thank you!
The GUI of AdGuard Home setting does not find the configuration backup/restore.
You can find the configuration of AdGuadrd Home in SSH to router,
path: /etc/AdGuardHome/config.yaml
Thanks for the reply, I've tried to SSH into it but I'm unable to locate the config. Any ideas?
Check the path you input, here is the ADG configuraion:
