Thanks I’ll wait for the next update ads drive me mad, thanks
Well security updates are useless if the router keeps crashing every day,
and unusable, i will stick with 4.5 that is stable
Is there a beta release for the Flint 2 with a fix for AdGuard yet, thanks
Has the Beta 4.6.4 Flint 2 address the problem for the AdGuard problem, thanks
The version fixed some problems of DNS. Can you have a try?
OK i have just installed 4.6.4 so i will run it and post back, i did notice though that with "Allow Custom DNS to Override VPN DNS" disabled after about ten minuets AD blocking stopped working, so i am now testing with it enabled
"Allow Custom DNS to Override VPN DNS" enabled AdGuard still working fine after 11 hours, I will keep running it but looks good so far.
So far so good I’m up to 2 days and 11 hours with Allow Custom DNS to Override VPN DNS enabled AdGuard works fine, looks like a very stable beta.
OK. Let me mask this as resolved.
Yes 3 days 23 hours still blocking ads.
