Adguard VPN Support
Hi, how can I configure the router to use my Adguard VPN subscription? And will there ever be support for it for GL-iNet
What support do you need?
I need to configure it on my router but there’s no guide on how to do it. Can you help me?
Adguard VPN is not supported on routers. They only have apps for Windows, Android, iOS, Mac and browser extensions. They use a proprietary VPN protocol, not OpenVPN nor WireGuard.
https://www.reddit.com/r/Adguard/comments/139lvqv/adguard_vpn_on_router/
Adguard use their own protocol, not openvpn and wireguard. Cannot be supported on the router.
