I got my replaced AR750S-ext back and all is working fine.
But I have one question concerning DoH.
I activated adguardhome and on the settings page–>DNS settings I entered “https://dns.quad9.net/dns-query” followed by test upstream “OK” and Apply “OK”
Flushed DNS cache on linux mint with “sudo /etc/init.d/dns-clean start” but when I visit 1.1.1.1/help it says still: |
Connected to 1.1.1.1|No|
Using DNS over HTTPS (DoH)|No|
Using DNS over TLS (DoT)|No|
Using DNS over WARP|No|
your initial Quad9 config most likely was working correctly.
issue was that you were using a cloudflare test site that tests if you’re using cloudflare.
there’s a reason why it’s not cloudflare by default
It is a non issue now, they just haven’t switched back. Cloudflare as a DNS will be slightly faster as well compared to Quad9 due to the incredible infrastructure Cloudflare has.
