ADGuardHome Failure after upgrade to 4.6.8 on BRUME2
I upgraded the firmware of my BRUME2 to ver.4.6.8 but upon reboot I could not access the ADGuard Home configuration page and I could no longer go to the internet. I restarted the router several times but always with the same problem, only by disabling ADGuard was I able to access the Internet. By enabling ADGuard I find these error messages in the router log
"Sat Nov 9 10:46:08 2024 user.notice AdGuardHome[18310]: 2024/11/09 10:46:08.874787 [info] AdGuard Home, version v0.107.52
Sat Nov 9 10:46:08 2024 user.notice AdGuardHome[18310]: 2024/11/09 10:46:08.882007 [error] parsing configuration file: Current schema version unknown 29
Sat Nov 9 10:46:13 2024 user.notice AdGuardHome[18359]: 2024/11/09 10:46:13.920729 [info] AdGuard Home, version v0.107.52
Sat Nov 9 10:46:13 2024 user.notice AdGuardHome[18359]: 2024/11/09 10:46:13.927335 [error] parsing configuration file: current schema version unknown 29
Sat Nov 9 10:46:18 2024 user.notice AdGuardHome[18379]: 2024/11/09 10:46:18.964843 [information] AdGuard Home, version v0.107.52
Sat Nov 9 10:46:18 2024 user.notice AdGuardHome[18379]: 2024/11/09 10:46:18.971333 [error] parsing configuration file: current schema version unknown 29"
Can anyone help me?
Thanks
Luigi
Seems like you upgraded AdGuard Home before and now you are running an older version again. (This is by design because the AGH bundled with the firmware is way older)
Disable AGH and update it again using [Script] Update AdGuard Home
Thanks admon for your support. I followed your guide and now it's working again...
Thanks Again
Next time when you upgrade firmware and keep backup only config.yaml in Adguard home. Then delete config.yaml and try upgrade Adguard home from @admon 's script. Finally put back Adguard config.yaml for restore your saved setting Adguard home.
How to get that file? Try use WinSPC for windows os
Overall reason config.yaml does have one line with number scheme version. If not match that upgraded firmware with old Adguard home base version then not working everything.
