When I toggled to enable the AdGuardHome a message “The API is unavailable” appeared. From this comment it seems possible to install it from Plug-ins
Ar750s with 3.201 firmware.
Thank you.
Thank you.
Please install gl-agh-stats
It’s worked. Thank you
Your solution will fix API issue on Mudi (GL-E750) as well.
Resolved issue on Brume MV-1000 as well, big thanks.
