Admin page not loading if connected to the web?
I had to reset my Mango since I set the network as hidden and forgot the access info. Now the admin page only shows it the router is offline. If I plug lan while in the admin page it still shows offline while I can access the net.
What is the IP address you got from the router on your PC?
What is the status of the LED?
I was using default IP 192.168.8.1 light 2 was turned off if I remember correctly. Now the problem is resolved since problem was in a hotel room. Now on my home network everything is working fine.
Maybe it is power issue. Did you use hotel wall power supply?
Could definitely be power, I was using the hotel router USB port to power the mango.
