I don’t know if I need to set some routing rule.
I tryed to set the gateway of lan interface (192.168.8.1) to my local network (192.168.195.1) but it is forgotten.and the filed returns to blank.
s.
s.
You can try to make it work in Access Point mode
The gateway IP address and the LAN interface IP address both have to be on the same IP subnet (192.168.x.y), in order for the gateway to be reachable on a LAN.
