I have GL-AX1800 device. I used the wizard to connect it to the dormitory WiFi network that uses WPA-EAP security.
There is some problem in that network so it may disconnect connected devices time by time. My laptop or cellphone reconnects automatically in a few seconds and there is no problem but GL-AX1800 did not try to reconnect. I checked and saw if I share my cellphone data it easily switches to that but I need it to keep retrying to connect to the same network -or any other one in the list- if all connections to all wifi networks failed.
How can I do this?
Note: I have access to device console via ssh
