Hi, I've just upgraded my GL-Mt3000 router to the latest firmware. After upgrade I wasn't able to login anymore, while using the right password. After power down and up the system is unreachable. No Wifi etc. What to do here??
If it is not reachable anymore, not by Wi-Fi nor by LAN, you might need to reset it:
- Try to reset it: Repair or Reset - GL.iNet Router Docs 4
- If this does not work, try to debrick: Debrick via Uboot - GL.iNet Router Docs 4
What is the LED status?
