AGH connect utility
Can some one help?
I can not connect AGH tool ( https://apps.apple.com/ru/app/adguard-home-remote/id1543143740 ) to AGH on Gl.iNet
On raspberry or vps it connect without any problems.
But on GlInet I try use port 3000 and 80, login and password Luci and Glinet - it can not connect
I don’t think it work.
The app needs to login using AdguardHome API. But on GL.iNet router, AdguardHome has been modified and the original login is not there anymore.
Is this app necessary?
if it is not provided, then there are no questions. i thought it was a bug
