Airtime Fairness. How do I check if its enabled? Slate AX
Im still learning OpenWrt and the commands via SSH. How do I check if Slate AX has airtime fairness enabled and how do I turn it On if its disabled?
Cheers.
edit;
I tried this command and im getting a list of denied permissions.
grep -rl "airtime" /sys
grep: /sys/bus/cpu/uevent: Permission denied
grep: /sys/bus/cpu/drivers_probe: Permission denied
grep: /sys/bus/i2c/drivers/tlc591xx/bind: Permission denied
grep: /sys/bus/i2c/drivers/tlc591xx/uevent: Permission denied
grep: /sys/bus/i2c/drivers/tlc591xx/unbind: Permission denied
grep: /sys/bus/i2c/drivers/nxp-ledseg-i2c/bind: Permission denied
grep: /sys/bus/i2c/drivers/nxp-ledseg-i2c/uevent: Permission denied
grep: /sys/bus/i2c/drivers/nxp-ledseg-i2c/unbind: Permission denied
grep: /sys/bus/i2c/drivers/dummy/bind: Permission denied
grep: /sys/bus/i2c/drivers/dummy/uevent: Permission denied
grep: /sys/bus/i2c/drivers/dummy/unbind: Permission denied
grep: /sys/bus/i2c/uevent: Permission denied
grep: /sys/bus/i2c/drivers_probe: Permission denied
grep: /sys/bus/mhi/drivers/MHI_DTR/bind: Permission denied
grep: /sys/bus/mhi/drivers/MHI_DTR/uevent: Permission denied
grep: /sys/bus/mhi/drivers/MHI_DTR/unbind: Permission denied
grep: /sys/bus/mhi/drivers/qcom_mhi_qrtr/bind: Permission denied
grep: /sys/bus/mhi/drivers/qcom_mhi_qrtr/uevent: Permission denied
grep: /sys/bus/mhi/drivers/qcom_mhi_qrtr/unbind: Permission denied
grep: /sys/bus/mhi/uevent: Permission denied
grep: /sys/bus/mhi/drivers_probe: Permission denied
grep: /sys/bus/mmc/drivers/mmcblk/bind: Permission denied
grep: /sys/bus/mmc/drivers/mmcblk/uevent: Permission denied
grep: /sys/bus/mmc/drivers/mmcblk/unbind: Permission denied
Airtime Fairness is already enabled in the default, and not recommended to close.
Why do you need it disable?
I don't want to disable it, I just want to check if its enabled in the first place.
Cheers.
