Allow access to upstream printer no longer available
Hello
I'm using Flint 2 with the latest OP24 update (September 2025) and I also use the router as NordVPN client. This router is connected via LAN cable to another upstream router from my provider and I have few devices on this network like printers and home appliances. When the NordVPN client is started I cannot access printers and devices on my upstream network. I need to stop the VPN in order to access these devices. In the previous firmwares there was an option called Allow access to upstream printer in the VPN dashboard that I do not find anymore. Is this a bug or something deliberate? Has the name of the feature been changed and/or moved to another place in the GUI?
Thanks
Please refer to Allow access to WAN when VPN client is enabled - GL.iNet Router Docs 4
Thanks. Will try this option and let you know.
