Allow inbound TCP for HTTP 80 and HTTPS 443 when VPN client is enabled
On the Flint 2 4.6.2 release 1 I have an issue where inbound TCP for HTTP 80 and HTTPS 443 are not allowed until VPN Client is disabled. I have the port forwards configured so I'm not sure what the issue is. The wan_in_conn_mark rule allows inbound TCP.
I'm using VPN Policy Based on Target Domain mode.
Inbound Wireguard-server with UDP seems to work fine, not sure why TCP is an issue with HTTP/HTTPS.
Inbound Plex server with TCP also seems to play up a bit but does seem to work, occasionally shows as no remote access in Plex then I refresh and it works fine. But with VPN client off it's reliable.
What I want to do is get my reverse proxy working, I don't want to enable WAN access to the Flint 2 router.
root@GL-MT6000:~# cat /etc/config/firewall
config defaults
        option syn_flood '1'
        option input 'ACCEPT'
        option output 'ACCEPT'
        option forward 'REJECT'
config zone
        option name 'lan'
        list network 'lan'
        option forward 'ACCEPT'
config zone
        option name 'wan'
        list network 'wan'
        list network 'wan6'
        list network 'wwan'
        list network 'secondwan'
        option mtu_fix '1'
        option input 'DROP'
        option masq '1'
config forwarding
        option src 'lan'
        option dest 'wan'
        option enabled '0'
config rule
        option src 'wan'
        option proto 'udp'
        option dest_port '68'
        option target 'ACCEPT'
        option family 'ipv4'
config rule
        option name 'Allow-IGMP'
        option src 'wan'
        option proto 'igmp'
config rule
        option name 'Allow-DHCPv6'
        option src 'wan'
        option proto 'udp'
        option dest_port '546'
        option family 'ipv6'
config rule
        option name 'Allow-MLD'
        option src 'wan'
        option proto 'icmp'
        option src_ip 'fe80::/10'
        list icmp_type '130/0'
        list icmp_type '131/0'
        list icmp_type '132/0'
        list icmp_type '143/0'
config rule
        option src 'wan'
        option proto 'icmp'
        list icmp_type 'echo-request'
        list icmp_type 'echo-reply'
        list icmp_type 'bad-header'
        option limit '1000/sec'
config rule
        option src 'wan'
        option dest '*'
        option proto 'icmp'
config rule
        option name 'Allow-IPSec-ESP'
        option src 'wan'
        option dest 'lan'
        option proto 'esp'
config rule
        option name 'Allow-ISAKMP'
        option src 'wan'
        option dest 'lan'
        option dest_port '500'
        option proto 'udp'
config rule
        option name 'Support-UDP-Traceroute'
        option src 'wan'
        option dest_port '33434:33689'
        option proto 'udp'
        option target 'REJECT'
        option enabled '0'
config include
config include 'nat6'
        option path '/etc/firewall.nat6'
        option reload '1'
config redirect 'dns_vpn'
        option name 'dns for vpn'
        option src 'lan'
        option src_dport '53'
        option dest 'lan'
        option dest_port '1653'
        option mark '!0x8000/0xc000'
        list proto 'tcp'
        list proto 'udp'
        option enabled '0'
config redirect 'dns_vpn_guest'
        option name 'dns for vpn guest'
        option src 'guest'
        option dest 'guest'
        list proto 'tcp'
        list proto 'udp'
        option enabled '0'
config rule 'process_mark'
        option name 'process_mark'
        option dest '*'
        option proto 'all'
        option extra '-m owner --gid-owner 65533'
        option target 'MARK'
        option set_xmark '0x8000/0xc000'
config rule 'process_mark_dns'
        option name 'process_mark_dns'
        option dest '*'
        option proto 'all'
        option extra '-m owner --gid-owner 453'
config rule 'process_explict_vpn'
        option name 'process_explict_vpn'
        option dest '*'
        option proto 'all'
        option extra '-m owner --gid-owner 20000'
        option set_xmark '0x20000/0x20000'
config rule 'wan_in_conn_mark'
        option name 'wan_in_conn_mark'
        option src 'wan'
        option dest '*'
        option extra '-m mark --mark 0x0/0x3f00 -j CONNMARK --set-xmark 0x8000/0xc000'
        list proto 'tcp'
        list proto 'udp'
        list proto 'tcp'
        list proto 'udp'
        list proto 'icmp'
        option enabled '1'
config rule 'lan_in_conn_mark_restore'
        option name 'lan_in_conn_mark_restore'
        option src 'lan'
        option dest '*'
        option extra '-m connmark --mark 0x8000/0xc000 -j CONNMARK --restore-mark'
        list proto 'tcp'
        list proto 'udp'
        list proto 'icmp'
        option enabled '1'
config rule 'out_conn_mark_restore'
        option name 'out_conn_mark_restore'
        option dest '*'
        list proto 'tcp'
        list proto 'udp'
        list proto 'icmp'
        option enabled '1'
config include 'swap_wan_in_conn_mark'
        option type 'script'
        option reload '1'
        option path '/etc/firewall.swap_wan_in_conn_mark.sh'
        option enabled '1'
config include 'glblock'
        option path '/usr/bin/gl_block.sh'
        option reload '1'
config zone
        option name 'guest'
        option network 'guest'
        option input 'REJECT'
config forwarding
        option src 'guest'
        option dest 'wan'
        option enabled '0'
config rule
        option name 'Allow-DHCP'
        option src 'guest'
        option proto 'udp'
        option dest_port '67-68'
config rule
        option name 'Allow-DNS'
        option src 'guest'
        option proto 'tcp udp'
        option dest_port '53'
config include 'vpn_server_policy'
        option path '/etc/firewall.vpn_server_policy.sh'
        option reload '1'
        option enabled '1'
config zone 'wgclient'
        option name 'wgclient'
        option forward 'DROP'
        option mtu_fix '1'
        option network 'wgclient'
        option masq '1'
        option masq6 '1'
        option enabled '1'
        option input 'DROP'
config forwarding 'wgclient2wan'
        option src 'wgclient'
        option dest 'wan'
        option enabled '1'
config forwarding 'lan2wgclient'
        option src 'lan'
        option dest 'wgclient'
        option enabled '1'
config forwarding 'guest2wgclient'
        option src 'guest'
        option enabled '1'
config rule 'sambasharewan'
        option src 'wan'
        option dest_port '137 138 139 445'
        option dest_proto 'tcpudp'
        option target 'DROP'
config rule 'sambasharelan'
        option src 'lan'
config rule 'glnas_ser'
        option src 'wan'
        option dest_port '6000-6002'
        option dest_proto 'tcp'
config rule 'webdav_wan'
        option src 'wan'
        option dest_port '6008'
config redirect
        option enabled '1'
        option proto 'tcp'
        option src_dport '80'
        option dest_ip 'REDACTED'
        option dest_port '80'
        option src 'wan'
        option name 'GL-http'
        option dest 'lan'
config redirect
        option enabled '1'
        option proto 'tcp'
        option src_dport '443'
        option dest_port '443'
        option src 'wan'
        option name 'GL-https'
        option dest 'lan'
config rule 'ping_wan'
        option src 'wan'
        option proto 'icmp'
        option icmp_type 'echo-request'
config forwarding 'wgclient2lan'
        option dest 'lan'
        option enabled '0'
@hansome any suggestions please?
Update. I rebuilt the router by resetting to avoid the problem in
And now everything works as expected with the VPN client enabled.
