KaKi87
glddns.com is fine for IPv4 but for IPv6 it only allows using its own, making it useless when needing to point to a LAN client (e.g. a server).
Therefore, it would be nice to add an option allowing to make the dynamic DNS to use said selected device’s IPv6 instead of its own.
Thanks
I believe gl ddns is still not compatible with IPv6.
Anyone can confirm that?
KaKi87
3
As I said, it actually is, but it creates an AAAA record pointing to the router itself, while I need to point to a server on my network.
Thanks
admon
4
That’s how it should be. DDNS is for the router only.
I got it ! That’s easy you can point it to any IP of your choice. The ddns update command can be found at:
/etc/ddns/services_ipv6
To construct the values needed for the update command, look at this script:
/usr/lib/ddns/dynamic_dns_updater.sh
