Hi gl.iNet Team,
Hope everybody is doing well.
Just wondering if there is any way to upload a batch of wireguard config files simultaneously.
Currently, we have devices with as many as 50x VPN profiles. Importing these manually is time-consuming and tedious.
Would it be possible to allow for the upload of either a ZIP with multiple configs in the same format compressed or simply by allowing the selection of multiple files when using the device web portal?
Please let me know if you require any further information
Look forward to hearing from you
Regards,
reCIPHER | Helpdesk
