Allow ping on WAN interface
apparently I am the first to ask that question. Is it possible to allow ping on the wan interface?
The rational behind is that I need to ping my Brume device for availability monitoring. I use this router as a VPN server only and therefore it’s only connected to my network via its wan interface.
Best
macx
You need to do this in luci.
Go to Luci->network->firewall and find wan. Set incoming to accept.
Thanks a lot for this hint.
But this looks to me like this allows any kind of traffic on the wan interface. Is it possible to only allow ICMP?
You are right.
Try add rule to allow ping. Someone like below. You can do in luci.
config rule
option name ‘Allow-Ping’
option src ‘wan’
option proto ‘icmp’
option icmp_type ‘echo-request’
option family ‘ipv4’
option target ‘ACCEPT’
