i noticed when i use GoodCloud or WireGuard to acces the Web UI of the rooter the Allowlist will not open. So when i am abroad i need to WOL and then Teamviewer or Anydesk to access it ?
I tried to reproduce the issue, but I didn't find it. Please check GoodCloud again.
It may be that the network is unstable and the blocklist top-up window has not been loaded.
Thanks for looking in this.
As soon i login via Goodcloud on Port 80 The Allowlist will not open.
Pls try to set a Mac adress into it - so there will be written allowlist instead blocklist.
It will not open.
Same when i acces the UI via WireGuard on MobilePhonebrowser.
Active WIFI Connection to Flint -> Allowlist opens
Connection via LTE/WireGuard the same (with ISP of SimCard). -> Allowlist not reacting
Thats means Allowlist will only open with direct Wifi or LAN, but not with WAN.
Did i miss a switch or setting ?
I did not reproduce, refer to the following screen recording.
Both allowlist and blocklist can be opened.
Please try changing another browser to test.
Please record a screen recording for description if no luck with other browser.
Hey Bruce thx for your reply.
I tryed it now with Opera GX, Safari and Microsoft Edge.
As soon i WireGuard to the Flint - i have no chance to open the Allowlist.
Same on the iPhone... connected to the Wifi the Allowlist opens, but connected via WireGuard (different wifi) i get no reaction. Tryed it on PC, Laptop and 2 different iPhones.
