I have AmneziaWG config and bought it from amnezia official premium
my beryl 7 is 4.9
I can add profile as wireguard but it doesn’t connect:
Mon Sep 21 16:54:29 2026 daemon.info dnsmasq[22850]: read /tmp/hosts/dhcp.wgclient2 - 4 names
Mon Sep 21 16:54:30 2026 daemon.notice netifd: Interface 'wgclient2' is now down
Mon Sep 21 16:54:30 2026 user.notice firewall: Reloading firewall due to ifdown of wgclient2 ()
Mon Sep 21 16:54:31 2026 user.notice vpn-failover-trigger: action=skip iface=wgclient2 source=hotplug reason=ifdown cause=iface_disabled
Mon Sep 21 16:55:50 2026 daemon.info dnsmasq[26983]: read /tmp/hosts/dhcp.wgclient2 - 4 names
Mon Sep 21 16:56:00 2026 daemon.notice netifd: Interface 'wgclient2' is setting up now
Mon Sep 21 16:56:01 2026 daemon.info dnsmasq[30338]: read /tmp/hosts/dhcp.wgclient2 - 4 names
Mon Sep 21 16:56:01 2026 daemon.info dnsmasq[30336]: read /tmp/hosts/dhcp.wgclient2 - 4 names
Mon Sep 21 16:56:30 2026 user.notice vpn-failover-watcher: action=trigger iface=wgclient2 source=setup-timeout reason=startup-connecting-timeout elapsed=30
Mon Sep 21 16:56:30 2026 user.notice vpn-failover-trigger: action=schedule iface=wgclient2 source=setup-timeout reason=startup-connecting-timeout tunnel_id=4086 delay=0s pid=31482
Mon Sep 21 16:56:30 2026 user.debug tunnel_id_4086: (tunnel-switch.sh:31) section=cfg0792bd, iface=wgclient2, via_type=wireguard, group_id=2813, shared_count=1
Mon Sep 21 16:56:38 2026 user.info tunnel_id_4086: (tunnel-switch.sh:15) interface wgclient2 still down after 8s, proceeding with failover
Mon Sep 21 16:57:46 2026 user.notice wireguard-debug: USER=root ifname=wgclient2 ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin peerpubkey=dlHPYAunccm5uUu3VKjvAdbIpaTrExPss9rbevKymVU= PWD=/
Mon Sep 21 16:57:48 2026 daemon.notice netifd: Interface 'wgclient2' is now down
Mon Sep 21 16:57:48 2026 daemon.notice netifd: Interface 'wgclient2' is setting up now
Mon Sep 21 16:57:49 2026 user.notice firewall: Reloading firewall due to ifdown of wgclient2 ()
Mon Sep 21 16:57:49 2026 user.notice vpn-failover-trigger: action=schedule iface=wgclient2 source=hotplug reason=ifdown tunnel_id=4086 delay=0s pid=2669
Mon Sep 21 16:57:50 2026 user.debug tunnel_id_4086: (tunnel-switch.sh:31) section=cfg0792bd, iface=wgclient2, via_type=wireguard, group_id=2813, shared_count=1
Mon Sep 21 16:57:50 2026 user.notice vpn-failover-watcher: action=exit iface=wgclient2 source=setup-timeout reason=startup-connecting-timeout result=not_eligible
Mon Sep 21 16:57:58 2026 user.info tunnel_id_4086: (tunnel-switch.sh:15) interface wgclient2 still down after 8s, proceeding with failover
my beryl 7 is 4.9
Server Address
146.70.179.164
Mon Sep 21 16:49:38 2026 daemon.notice netifd: wgclient2 (22125): Persistent keepalive interval is neither 0/off nor 1-65535: `25-35'
Mon Sep 21 16:49:38 2026 daemon.notice netifd: wgclient2 (22125): Configuration parsing error
Mon Sep 21 16:49:43 2026 user.notice vpn-failover-trigger: action=schedule iface=wgclient2 source=setup-failure reason=setup-failed tunnel_id=5207 delay=0s pid=22898
Mon Sep 21 16:49:43 2026 user.debug tunnel_id_5207: (tunnel-switch.sh:31) section=cfg0592bd, iface=wgclient2, via_type=wireguard, group_id=2813, shared_count=1
Mon Sep 21 16:49:44 2026 daemon.notice netifd: Interface 'wgclient2' is now down
Mon Sep 21 16:49:44 2026 daemon.notice netifd: Interface 'wgclient2' is setting up now
Mon Sep 21 16:49:45 2026 daemon.notice netifd: wgclient2 (23658): Persistent keepalive interval is neither 0/off nor 1-65535: `25-35'
Mon Sep 21 16:49:45 2026 daemon.notice netifd: wgclient2 (23658): Configuration parsing error
Mon Sep 21 16:49:50 2026 user.notice vpn-failover-trigger: action=skip iface=wgclient2 source=setup-failure reason=setup-failed tunnel_id=5207 cause=already_running
Mon Sep 21 16:49:51 2026 daemon.notice netifd: Interface 'wgclient2' is now down
Mon Sep 21 16:49:51 2026 daemon.notice netifd: Interface 'wgclient2' is setting up now
Mon Sep 21 16:49:51 2026 user.info tunnel_id_5207: (tunnel-switch.sh:15) interface wgclient2 still down after 8s, proceeding with failover
Mon Sep 21 16:49:51 2026 daemon.notice netifd: wgclient2 (25134): Persistent keepalive interval is neither 0/off nor 1-65535: `25-35'
Mon Sep 21 16:49:51 2026 daemon.notice netifd: wgclient2 (25134): Configuration parsing error
Mon Sep 21 16:49:56 2026 user.notice vpn-failover-trigger: action=schedule iface=wgclient2 source=setup-failure reason=setup-failed tunnel_id=5207 delay=0s pid=25858
Mon Sep 21 16:49:56 2026 user.debug tunnel_id_5207: (tunnel-switch.sh:31) section=cfg0592bd, iface=wgclient2, via_type=wireguard, group_id=2813, shared_count=1
Mon Sep 21 16:49:58 2026 daemon.notice netifd: Interface 'wgclient2' is now down
Mon Sep 21 16:49:58 2026 daemon.notice netifd: Interface 'wgclient2' is setting up now
Mon Sep 21 16:49:58 2026 daemon.notice netifd: wgclient2 (26611): Persistent keepalive interval is neither 0/off nor 1-65535: `25-35'
Mon Sep 21 16:49:58 2026 daemon.notice netifd: wgclient2 (26611): Configuration parsing error
in configuration it seems it drops H1,H2,H3,H4
[Interface]
Address = a.b.c.d
DNS = 100.64.0.1, 8.8.4.4
PrivateKey = …………………
Jc = 5
Jmin = 10
Jmax = 80
S1 = 910
S2 = 665
S3 = 1003
S4 = 12
H1 = 1
H2 = 2
H3 = 3
H4 = 4
HeaderProtectionKey = …………………………
RekeyAfterTime = 100-120
RekeyTimeout = 3-8
RejectAfterTime = 150-180
KeepaliveTimeout = 7-13
MaxHandshakeAttempts = 15-20
ContentPaddingAddition = 10-100
I1 = <b 0x4d455353414745207369703a39><rd 9><b 0x407369702e766b2e636f6d205349502f322e300d0a5669613a205349502f322e302f554450203139322e3136382e312e3130303a353036300d0a46726f6d3a202239><rd 9><b 0x22203c7369703a39><rd 9><b 0x407369702e766b2e636f6d3e3b7461673d36656533613930630d0a546f3a202239><rd 9><b 0x22203c7369703a39><rd 9><b 0x407369702e766b2e636f6d3e0d0a43616c6c2d49443a203831303434633364403139322e3136382e312e3130300d0a435365713a2031204d4553534147450d0a436f6e74656e742d547970653a20746578742f706c61696e3b20636861727365743d7574662d380d0a436f6e74656e742d4c656e6774683a2031390d0a0d0ad0b1d183d0b4d18320d0bfd0bed0b7d0b6d0b5>
[Peer]
PublicKey = ……………………
PresharedKey = ……………………..
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = e.f.g.h:6353
PersistentKeepalive = 25
They just relsesed an article about it.
Also, it kind of make all Amnezia Premium nor work with GLI-NET router anymore.
[image]
I hope to see a Beta Version on Berly and Brume 3 soon!
The issue is the Amnezia WG protocol was updated and all premium used 3.1 version.
Check the post.
They may updated this, but can take some time.
From Amnezia website : “If you use Amnezia Premium, you cannot set up VPN on your router using this guide. Amnezia Premium configuration files are issued only for AmneziaWG 3.1”
GL Inet routers is compatible with Amnezia 2.0 config files not (yet) 3.1.
