AmneziaWG 3.0 protocol has been released, it would be great if support in BerylAX and other gl-inet router would be upgraded from 2.0 to 3.0 version.
“We’ve rolled out a new app update. This release not only improves connection stability and security, but also fixes several bugs and brings a lot of useful features:
Configuration files are back*
Support for the updated AmneziaWG. Version 3.0 is already available to Premium and Free users. Version 3.1 is available for Self-hosted users.
Bug fixes. We’ve stabilized IP-based split tunneling, restored support for Ubuntu 22.04. and Debian 12, and more.
Read more on our blog. The update is now available for all operating systems on our website.
*Configuration files can be used, for example, in the AmneziaWG app to connect on older operating systems where the main client isn't supported. Currently, updated versions are available for iOS, Windows, and Linux. Android and macOS versions are pending moderation.
Important note about routers. Currently, Keenetic/Netcraze and OpenWrt do not support the AmneziaWG v3. The timeline for implementation depends solely on them. You can help speed up the rollout of protocol support — feel free to check the integration timeline directly with the manufacturers’ support teams.
Thanks for your suggestion.
We have recorded your request for AmneziaWG 3.0 support on Beryl AX (MT3000) and other GL.iNet routers, and submitted it to our development team for further evaluation.
Just a quick question when I set up the obfuscation parameters I had to remove everyhing behind the hyphen for the h1 to h4 parameters for it to work. According to AI its because the GL.iNet Web Admin Panel text validation fields do not support range notation.
Is this correct?
AmneziaWG 1.0 and 2.0 use slightly different obfuscation parameters: in v1.0, H1–H4 use fixed integer values, while v2.0 supports H1–H4 as value ranges and also introduces additional parameters such as S3–S4 and I1–I5 .
AmneziaWG 2.0 is supported on GL.iNet routers running firmware v4.9 or later.
Therefore, if your router is running an earlier firmware version that only supports AmneziaWG 1.0, the range portion after the hyphen in parameters such as H1–H4 may need to be removed.
Thank you for your interest in AmneziaWG 3.0/3.1 support.
The feature request has been forwarded to our development team for further evaluation.
At this time, we do not have a confirmed firmware version, release schedule, or list of router models that will receive AmneziaWG 3.0/3.1 support first.
If there are any updates or public beta releases in the future, we will share the relevant information on the forum.
Our team is still working on this feature, but unfortunately, we don't have a confirmed timeline to share at the moment. Thank you for your patience and understanding.
