Hi all. I really want to run AmneziaWG on a Flint2 router (GL-MT6000) Due to the fact that in the native firmware non-standard vermagic it is not possible to assemble kmod in any way. Is it really impossible to match vanilla OpenWRT vermagic? Is there any way around this issue without flashing to vanilla OpenWRT? I like the factory firmware and I need AmneziaWG VPN on my Flint2.
GL firmware does not support AmneziaVPN protocol for the time being.
But this request has submitted it to PM team, and they will seriously consider and evaluate it.
Currently you can ask the author (leninalive). Since the package is not part of the OpenWRT repo, but hope the author can help you with the request on OpenWRT.
The sad thing is that I can't install AmneziaWG not only in the stock firmware through its interface, but also ipk through luci. And I can't even create a FORK on github, because Flint2 has a modified kernel and every time I get a vermagic mismatch for the kmod part. Ideally, we would like native support, but it is much more important that vermagic coincides with vanilla OpenWRT and it is possible to fork on github.
You can try installing the op24-v4.7.5 firmware for MT6000, here provided vermagic configuration:
