Hello Iam a owner of the “Brume W” (GL-MV1000W),
I use the Brume over the Brume-WAN-Port, with a lan-cable-connection, behind my Fritz!Box.
Again: One end of the lan-cable plugs into the WAN-port of my Brume and the other end of the lan-cable
plugs into a lan-port of my Fritz!Box.
In my Fritz!Box I can see the mac-adress of my Brumme.
I will not post the real mac-adress in this posting …
I use an example:
The mac-adress in this example is:
00:80:41:ae:fd:14
My problem is:
After all the work to install my Brume in my network I found a unknown device, with the internal IP …
192.168.178.2
and the mac-adress of this unknown device is
00:80:41:ae:fd:15
The only difference between my Brume-mac-adress and the mac-adress from the “unknown device” is the last digit ( 4 and 5 ).
The DHCP-Server of my FritzBox creates only IPs, that starts with 20 (example 192.168.178.20)
What is this for a “device”?
A virtual machine on my Brume or something like this???
I dont know!
Iam very lucky when somebody can help!
I hope Iam right here in this Board!
Greetings from Germany and sorry for my bad english!
Netrix
