Android App - Parental control issue with OP24 4.83
Since updating to OP24 4.83 I’ve encountered an issue with parental control via the Android App. When I try to make a change or create a new block I get an ‘invalid’ notification in the app. I can only setup or modify times and days via the web browser. I did not have this issue when I was on an earlier no OP24 version of firmware.
On a side note, what version of OP24 is the new OP24 4.9 using? On the whole, happy with OP24 4.83.
Thank you for your report.
We have been able to reproduce the issue locally, and the development team plans to fix it in a future release.
For now, please continue using the Web interface for configuration.
At present, the v4.9.0-op24 OP version is still the same as v4.8.3-op24, both are 24.10.4.
We plan to update to v4.9.0-op25 in the future, but this will still take some time and no timeline is available yet.
v4.8.3-op24
root@GL-MT6000:~# cat /etc/glversion
4.8.3-op24
root@GL-MT6000:~# cat /etc/os-release
NAME="OpenWrt"
VERSION="24.10.4"
ID="openwrt"
ID_LIKE="lede openwrt"
PRETTY_NAME="OpenWrt 24.10.4"
VERSION_ID="24.10.4"
HOME_URL="https://openwrt.org/"
BUG_URL="https://bugs.openwrt.org/"
SUPPORT_URL="https://forum.openwrt.org/"
BUILD_ID=""
OPENWRT_BOARD="mediatek/filogic"
OPENWRT_ARCH="aarch64_cortex-a53"
OPENWRT_TAINTS="busybox override"
OPENWRT_DEVICE_MANUFACTURER="OpenWrt"
OPENWRT_DEVICE_MANUFACTURER_URL="https://openwrt.org/"
OPENWRT_DEVICE_PRODUCT="Generic"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="OpenWrt 24.10.4 r28959-29397011cc"
OPENWRT_BUILD_DATE="1760891865"
4.9.0-op24
4.9.0-op24
NAME="OpenWrt"
VERSION="24.10.4"
ID="openwrt"
BUILD_ID=""
