I have set up my Spitz with both a 2.4GHz and 5GHz wifi, and I can use both with other devices (eg my laptop) without any problem, but I can’t see the 5GHz network on my Pixel 2 - it only shows the 2.4GHz network, and that works fine.
I can, however, use a 5GHz wifi network on another router, so I know it’s not a problem with my Pixel 2 specifically.
OK, so, yeah, it works on the 2 digit channels, but none of the 3 digit channels work.
Is this a quirk of Android?
I see other people with the same problem:
I’ve been using the app ‘Wifi Analyzer’ to measure/etc and it seems to suggest I switch the channel to 149, 153, 157, or 161…‘better channels’, is says. I guess because no one else is using those. Perhaps there’s a good reason
Hrm, that’s interesting. How does it know where I am? GPS? What if I turn it off?
If I go to a different country with my device(s), does it then change which channels are available?
It all sounds very impractical.
Perhaps because my phone (Pixel 2) is American? I wonder if it was purchased in the USA…(it was supplied by my company, so I’m not sure).
It is not GPS, it is distinguished by country code, we have not made a distinction between different countries, if you must, you can try to modify on luci
Interesting. Maybe I’ll get something different if I take the sim out. I’m going to China tomorrow so that might give me a different result too. I’d be good to get one of those unused channels
With no sim it could well configure itself as the most restrictive settings valid everywhere. At most it may give you the settings for the region the device was originally set to be sold in.
This may help.
I don’t believe Spitz is DFS certified so any channel listed as DFS will not be usable.
