Hi, I want to put a longer antenna on the GL-AR150-Ext-2, but cannot find out what coax connection it is. It is obviously too small to be rg6, but what type is it?
It would be great if someone could help me out!
Inside it s uFL
Outside it is RP-SMA
Thank you so much for your reply. Would I buy a uFL or RP-SMA cable to extend the antenna?
You can just buy RP-SMA.
uFL cable is a short cable. The big antenna use RP-SMA.
