Antenna
Looking at adding a external Antenna for my Campervan
This,,, Poynting MIMO-3-V2-15 Transportation and Automotive Omni MIMO Antenna""
2x Cellular, 2x Wi-Fi and 1x GPS/GLONAS
Obviously the router has the 6 antenna ports and this Antenna only has 5,two wifi cables and 3 lte ,is it suitable without the other cable connected.
Thanks for a great support forum also
I assume the router you refer to the X3000.
Does the cellular antenna only support LTE? If there is a 5G/NR signal locally, may better consider using the antennas that supports 5G/NR band.
Although some LTE and NR share the same frequency band.
If have to connect to this one antenna kit, 4x4 MIMO cellular may be missing.
But the establishment of MIMO depends on the base station status and status.
I think most areas may not have 4x4 MIMO at present.
You can buy and test it. If the signal value is sufficient when connecting 3 cellular antennas, it can also be used in this way.
This is the Antenna cables ,do i really need a antenna connection for all ports on router,tia
As I said above, you need to look at it based on your usage environment and network environment.
If cellular only connect 3 interfaces, the signal strength may not be that good, or the rate may drop a little.
