Any beta firmware available for the Marble?
I see the Spitz Plus already has a beta firmware available GL.iNet download center
Will the Marble get a new version soon as it's been left on 4.5.19 since August and it's the same chipset as the X2000 and I'm sure the following Improvements and Big Fixes would be appreciated by all Marble owners:
Improvement
Optimize web interface.
Bug Fixes
Fixed an issue where enabling AdGuard Home would reset custom DNS encryption settings during configuration upgrades.
Fixed an IPv6 connectivity issue where PCs on the LAN side could not ping devices when in IPv6 Passthrough mode.
Fixed an issue where wireless switching would cause the repeater to disconnect when the repeater was enabled.
Sure, we are working on this.
The new firmware for Marble shall be v4.7.2 and the beta firmware is supposed to be available in a week, if everything goes well.
Thanks for the info!! I will install it and I will report anything bug (if there are present) :slight_smile:
I shall check back tomorrow then :slight_smile:
Sorry but some days delayed.
The beta firmware is available now.
Check it in this link:
Thanks!! Installed without issue. I will tell something if I see any issue.
Upgrade was weird, first local upgrade said not official firmware.
Also managed to out of memory the Marble.
Rebooted and installed fine.
I installed this firmware via Uboot and I did not experiment issues with this method.
How's your throughput, I have lost 27Mb on the download.
On my internet connection (1 Gbps theorical) always it has danced the speed between 750-900 Mbps. In 4.5.19 it was, in average, 850 Mbps, but in 4.7.2 it has been nerfed the speed too. I attach my Speedtest results here. Tests have been done with an Intel AX210 wifi card connected on the WiFi 6 network in the best channel I have been able to tune:
Can you run this from the terminal
I'm getting identical wired ethernet speed from WAN with 4.7.2 beta firmware vs 4.5.19
Yes, It works on my side. WiFi speed results are a bit better than Speedtest.
goodcloud incorrectly reports SSID visibility as hidden on 4.7.2 firmware on the Marble and Opal
Verified this issue, we shall fix it soon.
Sorry anyway for this trouble.
I don't use Goodcloud, so I could not reproduce the issue on 4.7.2. Thanks for the fix.
HI
Any news about an openwrt 24.10 based firmware for Marble ?
There's only two Qualcomm SDK that are available, 19.07 based which the current firmware is based on or the 23.05 one.
OP24 firmware for the Marble would be incredible though.
and this ?
That's using ath11k drivers, the current Qualcomm SDK that GL use is using ath12k drivers
