ccchan
September 8, 2020, 9:29pm
hi
wanna take brumeW onto street
and saw it use 5V 3A.
i did easily found such powerbank on shops,
but is there any recommendation or further
requirement?
as i know,
different voltage can fry a device,
yet if power bank s “A” is larger than
brumeW 's 3, this is ok.
thank you
ccchan
September 8, 2020, 9:30pm
2
and strangely i cant google answers on this.
limbot
September 8, 2020, 10:21pm
3
Brume uses 5v/2a and yes any powerbank that supplies 5v and 2A+ should be fine.
alzhao
September 9, 2020, 4:34am
4
New power banks have USB typeC and can output very high current now.
5V2A should works, but 5V3A is better.
ccchan
September 9, 2020, 8:22pm
5
hi,
i just visited xiaomi,
MOST of their powerbank /w type C, do support 5V 3A, BUT ALSO 9V 3A etc.
If I plug my brumeW into it, can I sure it will draw a 5V 3A and NOT a 9V 3A?
9V 3A may kill my brumeW?
thx
the most expensive one:
輸入規格 5V3A / 9V3A / 12V3A / 15V3A / 20V2.25A
輸出規格 45W MAX
USB-A(單口):5V2.4A / 9V2A / 12V1.5A
USB-A(雙口):5V3A
USB-C:5V3A / 9V3A / 12V3A / 15V3A / 20V2A
三口:5V5.4A / 9V3A / 12V3A / 15V3A / 20V2A
Johnex
September 9, 2020, 8:47pm
6
The powerbank will only output 9V/12V/15V/20V after it has successfully negotiated QuickCharge or USB-C PD with the device.
In the case of Brumme-W, it will only get 5V.
Since you are in HK, you could get something like a Blitzwolf from TaoBao, will be just as good as the Xiaomi. I personally own the BlitzWolf BW-P10 :
Has wireless charging too
For monster batteries, i have the HyperJuice 27000mah battery pack, has USB-C PD 100W to charge my laptop.
Notice the current is low, remember this is idle, not doing anything. It is also not the Brume-W, so no wifi. At full power, it will use much more.
alzhao
September 10, 2020, 9:51am
7
You are operating a power plant.
ccchan
September 10, 2020, 2:53pm
8
hi~
thx for reply.
how about the cable?
suppose I pick the xiaomi powerbank as above.
IF, IF I intentionally use a QC3.0 cable or a “9V inducer” cable from taobao,
will that fry my brumeW? thanks
I think I will buy the above xiaomi powerbank,
i am a Mi fans > <
good C/P.
ps: QC 3.0 cable means max 12V 3A:
|Quick Charge 3.0|3.6 V to 22 V[19] in 200 mV steps[15] |2.6 A or 4.6 A[19] |36 W (12 V⋅3 A)|* HVDCP+
Dual Charge+ (optional)
INOV 1.0 & 2.0
Battery Saver Technologies|
Johnex
September 10, 2020, 8:39pm
9
If you use a trigger of any kind you will blow your Brume-W. I supports only 5V.
You can use any USB-C cable such as Baseus (as i show in the photo above), but it must not trigger a voltage itself.
If you get a Xiaomi you must keep an eye on it. A lot of people have puffed batteries in them, you see that the aluminium shell starts to get fat, the battery inside is ready to blow up.
Nick_T
September 11, 2020, 6:17pm
10
Personally, I’d prefer an USB-C or USB-C with PD (Power Delivery) cable to the QC 3.0 cable or 9V inducer.
If you look at the Brume’s spec sheet the Brume requires 1x USB3.0 Type-C Power Supply. So, an USB-C or USB-C with PD (Power Delivery) cable is more suitable.
Is your power bank you’re getting PD compatible?
Johnex
September 11, 2020, 6:22pm
11
Brume does not have USB-C PD capability, you can see my photo higher up, it will only use 5V, legacy USB power.
The plug is USB-C but only compliant in the lowest level.
You can use a USB-A to USB-C cable, or USB-C to USB-C cable, its up to you how much you want to spend on the cable, it does no difference.
ccchan
September 12, 2020, 7:40am
12
thanks all,
i will just get the cheapest powerbank (5V 2-3A or more), and buy a plain USB-c cable for that.
Nick_T
September 12, 2020, 11:08am
13
Just a reminder
get a reliable Brand powerbank and cable.
