Any way to enable Retina / HiDPI on MacBook?
I’m only getting the regular non-HiDPI resolutions when i plug my mac through the comet. everything works, but the text looks a little fuzzy compared to what i’m used to on retina. has anyone managed to get retina-style scaling / HiDPI output working through this kvm? any special settings, edid tweaks that helped?
First, you need to determine the actual resolution of your MacBook, and then find and use an EDID with the exact same resolution.
