any way to use GLDDNS behind another router?
any way to use GLDDNS behind another router? I want to make VPN through my router behind ISP router. If no, there is not a problem, I will use duckdns. But I still prefer GL products.
DDNS only works, if I'm not wrong, when the router is in Routing mode, not in Access Point or WDS modes. Perhaps you should configure your ISP router as bridge and put your GL.Inet router as Routing mode to get this feature.
See Script: Use GLDDNS behind another router [Testing!]
