Anyone Help with PuTTY & Tftpd64
I haven’t use uboot for a long time. But first, you need to know how to use the following commands
printenv
setenv
The first one print out the env variables. While the setenv will set the variables.
You will see all the preconfigured uboot tools there. One variables is the server IP address which you must make it correctly.
My problem is I can obviously ping the network card but I can’t ping the router on any ip address eg 192.168.1.1 or the original 192.168.2.1 or the serial 10.10.10.123, I’ve tried even the WAN port as well as all 4 LAN ports, it does have a USB port that’s all that’s left, my only hope would be to find someone worked for Afoundry, I got my original files from the tech guy at Afoundry, yesterday I found his email address but it bounced back.
Thanks again for everyone’s help.
:slight_smile: good luck!
Thanks that was different
