Anyone know how to install Docker on MT-1300? because I want to install strongswan and adguard on it.
thanks
thanks
ssh to your router and it’s pretty much command line linux … if you’re advanced enough to follow these guys it might be possible. I haven’t looked at the memory of the '1300 so you’ll need to make sure there’s enough.
I didn’t look far enough to see if they used an x86 machine - if so you’ll have to compile the package for this processor … above my pay grade ;]
I think this is difficult.
