Anyone using XE3000 with US Mobile?
Kernel Version: 5.4.21
Current Firmware - Version: 4.0
Firmware Type: 0704release5
US mobile physical sim registered to network
I have a phone I am not currently using so used that IMEI on the router
I cannot get any internet data from the router when it finally connects on DARK STAR
currently on apn of broadband with TTL at 64
Ive seen other posts about ATT not working with non data sims due to tethering entitlement checks?
looking for help!
It seems US mobile uses APN "ereseller" for DARK STAR network. Please change APN to ereseller and try again.
While not specific to Dark Star, I'll add that US-Mobile Lightspeed (T-Mobile) network does work as I'm currently using a US Mobile Lightspeed physical sim in my X3000.
Also, it's my understanding that the TTL value that is input in the GUI is at the router level so to get a outgoing TTL of 64 you want to set the router to 65 and it will decrement to 64 at the modem. Perhaps GL-iNet can confirm this assumption.
Yeah the TTL value set in the GUI is the at the router level. As far as I know the US Mobile requires specific APN settings for different network. The issue might be more related to the APN configuration.
