I am currently working with the developer API for GL-iNet router and I was able to view it through Loading.... I see that the API documentation is generated using https://apidocjs.com/ and with this I wanted to ask would it be possible to acquire the apidoc file itself with the Java-doc style comments so I can use that to convert the API to OpenAPI?
Thanks for getting back to me so quickly. I am familiar with the webpage you provided but I am looking to see if I could get the source API file from you that has the Java-doc comments used with APIDocsJs when the docs are generated if that would be possible?
I ask as there is a tool on Github that allows the generation of a OpenAPI spec using the APIDocsJs comments, it can be found here: GitHub - amanoooo/apidoc-swagger-3
