API status...
GL-AR750S Slate
Connected via ethernet to Starlink and via USB to T-Mobile hotspot
DNS servers 1.1.1.1 and 8.8.8.8
Static Network Addresses
I just upgraded router firmware from 3.104 to 4.3.10 and the devices using the Rest API are confused and so am I. The documentation page just says it is closed.
Does anyone know the current status of the Rest API?
The api of 4.x is very different from the 3.x.
Unfortunately we don’t publish the api for now.
If you use for personal you can try capturing from your browser.
If you use for businesses you can write to us via email.
