API to send SMS
I would like to buy the GL-X3000 router but I need to be able to send SMS remotely via API. Is there any system (even third-party) to fulfill this job?
GL firmware support this API. Please surely the phone card supports the SMS to send and receive.
curl -k http://127.0.0.1/rpc -H 'glinet: 1' -d '{"jsonrpc":"2.0","method":"call","params":["","modem","get_sms_list",{"bus":"1-1","phone_number":"8617603079726","body":"hello","timeout":10}],"id":1}'
Request parameters:
Field Type Description
bus string The PCIe path (Format: {domain}:{bus}:{slot}.{func}) or the USB path (Format: {bus}-{port[.port[.port]]}) for the cellular modem, depends on how the modem is connected, which can be gotten from the get_info interface
phone_number string The target number to receive SMS, it contains the country code, such as 8617603079726
body string The SMS content (no more than 140 Bytes)
timeout number Timeout time (Unit: Seconds), if the value is set to 0, it means that it will return immediately without waiting for the sending result
Thank you!
Does the GL-X3000 router also support sending RCS messages?
RCS does not support
One last question @bruce with your rpc api do I have the possibility to choose which of the 2 sims to use to send the sms? (The router supports 2 sims)
API does not support to switch the SIM card yet but AT command:
Switch to SIM 1:gl_modem -B 0001:01:00.0 AT AT+QUIMSLOT=1
Switch to SIM 2:gl_modem -B 0001:01:00.0 AT AT+QUIMSLOT=2
Sorry for asking this again - I have a SpritzV2 and want to send SMS messages via API from my laptop - is there a way to do this?
Please email to [email protected], explains why you need to use API to send SMS, which is a team or individual developer, etc.
I use sms.to for sending messages. Worked fine on my GL.iNet router using a shell script. It's quick to set up and doesn’t need anything complex.
