App Feature Request
Hi, I don't know where to put this topic, in the glinet app I miss the icon where the mobile coverage is shown as when you enter the ip of the router directly as shown in the attached image:
Please add this feature for next versions, it will be great for all of us. Thank you.
Do you want to have this icon on app?
Hi, both coverage signal and band will be great. Thanks. Regards
I mean do you want to display similar ICONS on app?
yes, because on the app i cant see it like the router admin page. regards.
okay, feedback has been given to the corresponding colleagues
Ok , thank you . :slight_smile:
